993 Forum 1995-1998
Speedo off. Regearing?
Old Jun 11, 2016 | 11:16 AM
Bill Verburg's Avatar
Bill Verburg
Originally Posted by JPS
I've switched to 18". Hard to believe overall diameter, hence circimference, would be less than stock.
Speedo showing 140 when 130 would seem to indicate less circimference from same wheel hub spins resulting in less distance traveled than speedo would think.
I never said that the tires don't make a difference, but it's the front tires and it has nothing to do w/ the transmission or rear tires.
Old Jun 11, 2016 | 11:23 AM
centerpunch's Avatar
centerpunch
All the different tire sizes and wheel sizes used on these cars have virtually identical overall diameters.
Old Jun 11, 2016 | 12:10 PM
JPS's Avatar
JPS
Oh I get that, Bill. I'm just disappointed that the gauge is off that much with what should be a diameter pretty close to stock.
Old Jun 11, 2016 | 01:04 PM
Bill Verburg
225/40 x18 & 205/50 x17 & 205/55 x16 are the 3 main front tires that came on a 993, all are ~25.1" OD
Old Jun 11, 2016 | 01:27 PM
bobbyp's Avatar
bobbyp
Assuming we are all running approximate factory diameter tires, since JPS and NYC993 have speedometers that show higher than actual while I show lower than actual, the issue is more of quality control at the factory or wear items within the speedometer.
Does this also manifest itself in the odometer? Not that it makes much difference but does my car at 100k miles really have 103k? Does JPS' at 100k miles really have 97k miles?
Old Jun 11, 2016 | 01:59 PM
Bill Verburg
That may be, I rarely look at the speedometer.
Old Jun 12, 2016 | 10:11 AM
Coleman's Avatar
Coleman
This could be an easy fix..
http://www.yellr.com/yb_home.htm It's a pulse re-calibrator for speedos.
With 18" rims on my car, the speedo is about 5mph faster @ 75mph actual.
C.
Old Jun 12, 2016 | 11:05 AM
JPS's Avatar
JPS
That's interesting. Which model would fit a 993? I suppose one would just intercept the signal coming out of the DME?
