Just picked up a pair of Turbo S ducts and was going to order some paint from TouchUpDirect. But I am bit confused about the available codes for Black Metallic. My paint code says Black Metallic Z8, but also show the number 744 which is on my sticker as well. I believe I should order 738/Z8, just need to make sure its the right one.
Hmm, from what I understand and per your under hood sticker, your paint color code is L744, so you would want to order, black metallic, 738/Z8 744.
On the touchupdirect web site, I selected automotive, porsche, 1997, all.
I got a different paint panel to choose from, than the one you posted. Heres the link...
PICK YOUR COLOR
Arctic Silver Metallic
92T/X1 92U/X1
Arena Red Pearl
84R/H8 84S
Black
741/A1 747
Black Metallic
738/Z8 744
Blue Turquoise
3AR/J1 3AS
Felgen Silver Metallic
61A
Glacier White
3AU
Glacier White
3AT
Guards Red
80K/G1 84A
Ocean Blue Metallic
3AY/E1 3AZ/E1
Ocean Jade Metallic
25H/J3 25K/J3
Pastel Yellow
12L/Q1 12M
Zenith Blue Metallic
3AW/F1 3AX/F1
PICK YOUR PRODUCT
All of our touch up paint colors are available in six different sizes to accommodate the smallest to the biggest project.
Not sure which product size is best for your project? Check out our Product Size Comparison.
YOU MUST FIRST SELECT YOUR COLOR.
PICK YOUR PACKAGE
Packages provide you with a complete toolkit to assist in perfect touch up paint results.
Take note that all TouchUpDirect paints require clear coat which is included in our Essential, Preferred and Platinum packages.
FYI, called them today and I guess all of the Black Metallic are suppose to be the same. Guess Porsche can be tricky with paint codes. 744, 738/z8 and 746 all the same color mixture. Let's hope
