pulls to right
pulls to right
hi guys just had corner balance and alignment done on car after instaling h and r coil overs.
i had set to rs ride height and camber specs. on first drive car pulls to right on higway on flat surface at all diferent speeds, is this bad alignment job? thanks armand
Could be a bad alignment; however, if you've gone to more aggressive camber and suspension settings, it also may be that you're just tramlining to the camber in the road. Even if the road looks flat, it takes very little road camber to have the car "pull".
Does it do it on all roads, and always to the right? My car will "pull" slightly to the right when in the far right lane of some 3 lane highways and pull slightly to the left when in the far left lane of those same roads.
the car pulls on all roads. i dont have the print out . i am bringing it back to be re checked . thanks for the input guys.. <img border="0" alt="[byebye]" title="" src="graemlins/wave.gif" />
