993 Forum 1995-1998
What lube for shifter?
Old Feb 18, 2002 | 09:46 PM
Robert Henriksen's Avatar
Robert Henriksen
Question What lube for shifter?
I decided to pull the console & eyeball the shifter assembly, w. an eye towards giving it some lubrication, do what I can to free up the shifter linkage.
I'm all the way down in there, and am now wondering... what should I use? I'd started on this because of someone else's post about doing same, and I believe they'd sprayed a silicone lube down onto the tube which holds the assembly.
But the stuff caked up around the perimeter of the collar looks pretty thick; I'm wondering if I should use grease instead of a silicone spray.
I read through volume II of the 993 service manual, but the only thing I found was on adjusting the fore-aft angle of the lever. Maybe this was covered in an earlier edition?
TIA,
RNH
Old Feb 18, 2002 | 11:59 PM
Timothy Stewart's Avatar
Timothy Stewart
Post
I used Valvoline Synpower for point application
on the linkages.
I used a moly-sulfide grease on the slider.
tim
Old Feb 19, 2002 | 03:08 AM
Barney's Avatar
Barney
Post
" I decided to pull the console & eyeball the shifter assembly " Would it be possible to explain as an answer how this is done? I would also like to lube the shifter, see if that improves things.
Old Feb 19, 2002 | 10:31 AM
Robert Henriksen
Post
I'll take some pictures during the reassembly & post them to Robin's site. Most of it is really, really straightforward - all exposed phillips screws holding the whole thing together. The only trick thing is getting the leather shift boot disengaged from the console. That's already written up in a couple of different threads, but I'll cover it w. pictures too.
If you're prone to occasional fits of OCD/Concours-like cleaning, this is a great time to do it
