Interesting preventative measure. Did you drill out the existing hub or is it a hollow rivet you just slipped the machine screw through?
Andy
Just a tiny machine screw, flat washers, nylock nut, slipped thru. Looks close in pic, but actually plenty of clearance. Figured if original bearing failed, I'd get some tell tale noise, before wheel fell off into abyss.
