Mobil 1 0-40 necessary
Haiku Grasshoppa
Can I Drove Your Car?
E.J.,
You've got it all wrong... I don't care about extending the life of my motor by switching to 0w40, I'm just looking for the extra 1 or 2 hp.
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
[quote]Originally posted by E. J.:
<strong>I have to say this thread has me a little perplexed. I obviously only use Mobil 1 and I cant imagine the specific viscosity really matters this much? E. J.</strong><hr></blockquote>
C'mon, EJ, you know the schoolbus is sick of that thick-like-molasses Guiness nonsense. What it's really looking for is some thin, Fishman-style Miller Lite to let the "components" slosh around a bit easier when you're just getting started!
Numerous scientific studies prove that Greg's insides show less "wear and tear" and smoother lifter operation than mine, especially in the fast corners.
<img src="graemlins/drink.gif" border="0" alt="[cherrsagai]" />
From a Mobil website:
"Q If I want to start using Mobil 1 now, will it mix with my old engine oil?
A Mobil 1 mixes with any engine oil - even non-synthetic mineral oils. However, to get the maximum benefits from Mobil 1 you should completely drain your engine and replace with Mobil 1."
I hope that puts peoples' minds at ease
source: <a href="http://www.prod.mobil.co.uk/automotive/index.html" target="_blank">http://www.prod.mobil.co.uk/automotive/index.html</a>
Graham
Graham
The cars came from the factory with Mobil One 5w40.
Up until a few months ago, you couldn't buy any Mobil One in the US that was a 40 weight, so many started using 50 weight. Now that 0w40 is available here, I think its a "no brainer" that the 40 weight is the one to use no matter where you live.
Here is a relatively low hassle compromise to the 0W-40 vs. 15W-50 debate: Make your own 7.5W-40 by mixing equal parts of easily obtainable Mobil 1 0W-30 and 15W-50. Simple to do at oil change time.
Chip
Chip
My mechanic flat out refuses to put 0-40 in the 911 engines! He is a race engineer running 911's for the last 3 decades so he knows a few things...
After I saw the condition my 0-40 oil was coming out of the car with just 1500 miles on it ( 2 DE's and street) I was too convinced of the value of 15-50 especially in areas as hot as Houston.
Porsche used to recommend 15-50 oil. Now they changed their tune...I wonder why! I'll stick to 15-50 thank you!
Why not use Castrol Syntec 5W-50? It is on Porsche's latest "approved oils" list IIRC.
On the Mobil1 website, Mobil has the following ambiguous comment on the question "Why do Castrol and others market SAE 5W-50 grade synthetic motor oil while ExxonMobil in North America does not? Does SAE 5W-50 offer advantages?"
-> "SAE 5W-50 is not recommended for the vast majority of newer cars sold in North America. They are designed for SAE 0W-30, 0W-40, 5W-30 and 10W-30 grades...and this is what car manufacturers recommend."
(Click here to see for yourself... <a href="http://www.mobil1.com/products/faq.jsp?catId=19#faq2" target="_blank">link</a>)
