Garage space heater? Help identifying most effective one.
#31
I purchased a heater similar to the one I referenced above at Menards for ~ $120 to hold me over until I ultimately decided on which system to go with. That cheap kerosene heater worked out so well I'm very glad I bought it, there was no need for anything more for my needs at least.
Good Luck in the search.................
#32
It seems to me that any sort of radiant induction heater will make for hot spots and will take a little while to provide overall warmth. Some sort of forced air solution will warm things up overall better. I believe a forced air solution can be had in portable and fixed mount veriety. The exposed heating element solutions may provide a point of ignition if volitile solvents or fuel are open near by.
Andy
Andy
#33
I have this 240v, 4800 watt Dimplex shop heater hanging in my garage and with the Automatic temperature control helps maintain consistent temperature from 45 to 77°F.
Cheap (not the cheapest option to run) and does the job for me.
#34
I had one of those too-in Dallas. Not exactly the frigid north, but we had some cold spells. Kept my 3 car garage warm one winter while I built an airplane in my 3 car garage, including the paint booth where I laid down a coat of dope almost every morning at 5am for about 3 weeks.
#35
There are times it does get frigid in this part of Michigan. I went with a Gas fired Infrared tube heater (20,000 - 25,0000 BTU) and 6 inches of closed cell foam insulation on the ceiling. The tool shed’s shape didn’t allow me to use the conventional systems so went with a serpentine shape from SunTube. It’s designed for a suspended ceiling drop in. While it’s not the cheapest approach the infrared energy heats the concrete floor. This makes a nice working environment, when its subzero outside.
