993 Forum 1995-1998
How do I clean the rubber on the tach?
Old Nov 27, 2015 | 09:01 PM
sambeckett78's Avatar
sambeckett78
Default How do I clean the rubber on the tach?
Hi All,
Any recommendations on how to clean up the grime(?) on the rubber seals surrounding the tachometer and speedometer (see picture).
Thank you, guys.
File Type: jpg
Old Nov 27, 2015 | 09:07 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I use Aerospace 404 on a Q-Tip.
Old Nov 27, 2015 | 09:22 PM
pilotjosh's Avatar
pilotjosh
Aerospace 303? Or is this a different product you're referring to?
Old Nov 27, 2015 | 10:35 PM
Christian J's Avatar
Christian J
303, 404, whatever it takes....
I removed the gauges to ge-grunge. an application of 303 lasts more than a year.
Old Nov 27, 2015 | 11:07 PM
mpruden's Avatar
mpruden
I've removed the rubber rings, scraped off the brown hardened rubber with sandpaper, soaked in 303, then reassemble. Looks brand new after that process a couple years ago.
Old Nov 28, 2015 | 01:09 AM
pilotjosh's Avatar
pilotjosh
Ha ha ha..
Old Dec 1, 2015 | 01:40 AM
sambeckett78
Thanks for the advice... I'll give Aerospace 303 a try.
