FYI An insidious potential power robbing vacuum leak you may have and are unaware of.
Just checked one of the actuators on a whim and stumbled across the issue.
Andy
The recirc door is right behind the CCU.
The latest actuators appear to use silicone diaphragms (vs. rubber in the originals), easy to tell as they are whitish vs. the black originals. I think the actuator arms are molded in a single piece vs. the threaded adjustable arms in the originals too. No difference to function except that you can't swap them around anymore as the arms are different lengths on a couple of them.
Is that what you found? Or were you able to source & replace just the vacuum unit?
I smoked the manifold , found a few leaks and also doubled the vacuum capacity. The one under the dash escaped detection until I had a really good shop dyno the car and then look into it as you could see that it was falling flat at high revs. They found the leak under the dash which was missed by myself and 2 other shops. As part of the repair they added a check valve to prevent a repeat. The whole repair took less than 30 min. to complete once the leak was found. The next dyno was proof of the damage that was being done.
RL Technical Advisor
FWIW, we always replace ALL of the little rubber vacuum fittings in the engine compartment whenever the engine is out for a top-end or complete rebuild. Such items do deteriorate over time from heat & age and can be the source of all kinds of running issues.
Interesting the local BMW dealer called me back as the equivilant BMW part number fits a car only sold in the EC. I guess I will need to call my friend in Muchen to buy one for me if I want the part.
Andy I'll check if they're available here as we make most of the 3 series cars here ...
when smoking the intake do you just introduce the smoke to the intake airfilter opening?
It is not fun chasing vac leaks. I bought a $40 smoke/fog machine from Party Central. It worked okay. What ended up being the most effective was to simply pressurize the intake with air to about 5 psi. Then use the smoke machine around the area of testing and watch as the leaky area swirl the smoke!!!
I'm wondering how best to seal the intake (plastic wrap over air filter?) and where to introduce the smoke (will any easily accessible line do the trick?).
Also, you'd have to build a low pressure smoke machine. There are DIY examples floating around the web. Some are quite humorous.
