Trailer hitch for my 993
I am ready to buy a hitch but I would like some comments from anyone who has done this first hand. I am looking at two different hitches. I will be using it to tow a small utility trailer with my track wheels, jack, and tool box.
Here are the two I am looking at.
<a href="http://www.evoms.com/press_release%20swifttow.htm" target="_blank">http://www.evoms.com/press_release%20swifttow.htm</a>
<a href="http://www.hitch-web.com/proDescrip.asp?ProductCode=5432&OID=8" target="_blank">http://www.hitch-web.com/proDescrip.asp?ProductCode=5432&OID=8</a>
Thank you in advance for any comments.
Don Ehinger
Don Ehinger
Hi,
Someone on this board commented that the DaLan hitch might rub against the rear fender. Unless there is a solution to this problem I'd go with the Evom hitch.
Tom
Tom
Glad to see someone finally building a hitch. The EVOMS unit looks good. I built my own about 3 years ago, but that design looks much better. If you search the archives under my member number, you will find lots of threads about trailers and hitches.
E. J.
E. J.
E.J.
Which member number do I use to search the archives? Do I just put your member number in the search?
Thanks for the help.
Don
Don
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by 993944S2:
<strong>E.J.
Don</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">In the search screen, there is a section called "Search by Registered Member Number". Put 171 in there. You can also put the words "trailer hitch" in the "Search Words" section.
<strong>E.J.
