PSS10 52MM Locknut
Looking for PSS10 52MM small locknut part number. I want to add a second locknut at the bottom of the rear drop link bracket, that will not interfear with the head of the drop link. I have already received two from Bilstein part no. E4-FT4-Z003A05 that are too large. Not getting much help from Bilstein.
Thanks,
Rick
Thanks,
Rick
You need two...
If you are referring to the ID (thread) being wrong:
Ive had problems with Billstein too... Ive ordered multiple sets from them, there are definitely two sizes. I don't have the part numbers handy.. but press the folks at Bilstein, they have the right parts, you just have to find them...
If you are referring to the OD:
Yes you will have to some mild filing to the drop link bracket to relieve interference with the additional lock ring.
