95 Non-Immobilizer DME
Hi,
I am looking for a good 95' non-immobilizer DME to use to test my car to see if it solves the occasional starting issues. I would like to either borrow/rent one or possibly buy a used one to keep the car on the road when mine is out for repair/rebuild. To be clear, I am talking about the DME under the seat that holds the chip, not the DME relay.
Thank you!
Mike
Thank you!
Mike
Could one just wire the DME relay directly to the ignition switch and defeat the imobalizer without an invasive change to the DME software?
