nice surprise with the Fister 3
^^^^^^ without a change (or removal of cats) the flow is not enhanced, by just about any muffler. The beautiful sound, creates a euphoric effect, which tricks the brain into thinking you have more HP. Just like "crack".
Thanks for clarification. Guess I'll stay with crack!😉
...Are you speaking from experience? ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Less rotating mass within the engine (LWFW) allows the motor to spin up faster without making a nat's *** more hp.
Want your car to feel like its got more HP/torque; lighten the load...Sprung and unsprung; rotating mass or otherwise.
That, and the Fisters prolly wont kill you as quickly, or devastate your bank account!
I do not want to nitpick, but if it revs faster, wouldn´t it actually have more horsepower?
The only downfall of using the "Fisters" as a drug instead of crack, is you can't get SSI disability income for your "disability".
And sorry for hijacking the thread!
Okay, now I might sound very dumb, but... I always thought that when the flywheel is lightened there is also less power lost in the drivetrain, which then translates into minor power gain on the wheels, while the power on the crank stays the same. So not only the engine "moves" quicker while off gear, since the flywheel holds less momentum, it also means there is more power on the ground, therefore the car accelerates faster and therefore the engine rise up in revs faster too, while actually under load. Not saying it is a huge difference, just that it is there. Am I completely bollocks? ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
You're not completely "bollocks". Pull about 25 lbs of rotating mass, directly off of the end of the crank, can/should equal a measurable (albeit tiny) increase in power. Not just faster revving, but an increase of output due to loss of restriction (weight). I may be "completely bollocks", but common sense says if the engine produces a certain amount of HP at a given weight, reducing the draw on the engine, should free up extra hp. Maybe I just need another drink.
Also I´ve never looked that B word up in the dictionary, so I might used it in a completely inappropriate way.
It's very possible your old exhaust system was restricted in some way....Rust, mouse turds whatever from sitting....and now you have a normal exhaust, so no crack...except maybe your butt crack if your into the new fad wearing your pants around your knees.
