993 Forum 1995-1998
993 tire sizes
Old Jun 12, 2015 | 11:22 AM
Gjbacci's Avatar
Gjbacci
Default 993 tire sizes
I have a 1996 Targa with 17" stock cup design wheels. Tire rack and the Porsche bulletin shows the front tire size as 205/50/ZR17. I currently have P zero's on the front which are 225/45/ZR17. Backs are 255/40/ZR17 as shown in the technical bulletin.
Putting on PSS10, lowering a bit below stock, changing to Sumi III's and having a wheel alignment.
Question - Should I go back to the stock size in the front? I am not really sure why I have different size. Maybe just a discount tire screw up.
Any advice would be appreciated.
Old Jun 12, 2015 | 12:40 PM
MD993's Avatar
MD993
In my old 993 I had the same setup as you 225 front and 255 back and it was amazing !! A little bump steer more, but very little or no understeer....
In my "new" 993 I have stock 205 front and 255 rear... The steering is lighter and more responsive, but there is understeer in the front... Oversteer is less imminent in this setup...
Between the two, I prefer the first to the later... So keep 225 in the front, in my opinion...
Old Jun 12, 2015 | 01:43 PM
Donster's Avatar
Donster
My car came with Sumi III and I hated them. Recommend you reconsider that choice. Swapped them for Michelin PS2 and find my handling a little sharper, wet traction better and ride a lot smoother. I know they're rated ok in some tests but it puzzles me why anyone would put such cheap tires on a nice car.
Old Jun 12, 2015 | 02:16 PM
P-daddy's Avatar
P-daddy
My C2 came with same size set-up as yours. Handles beautifully with the right suspension/alignment.
Old Jun 12, 2015 | 03:00 PM
nile13's Avatar
nile13
The car came with 205 and many replaced them with 225s upfront for less understeer.
Having said that, OP's description is all over the map. What is it that you want to do with the car, what's important to you? Right now you are throwing money at lemming uniform. It might work for you, but now's a good time to consider what you really need and want out of the car so you don't end up throwing that money at it twice.
Old Jul 21, 2015 | 01:10 AM
FLYT993's Avatar
FLYT993
this is the set up i have on my C4 with AD08's. my 10's are set up at 6F/5R...she's lowered, aligned, and balanced and she is agile and sticks.
Old Jul 21, 2015 | 01:17 AM
IainM's Avatar
IainM
[QUOTE=MD993;12354381A little bump steer more, but very little or no understeer....[/QUOTE]
...indicates poor alignment job in my mind. Should never have bump steer on properly set up 993.
I have 18's and am wondering how a well set up 17" or even original 16" wheel set would be like. There's a lot of unsprung mass added for bigger tires/wheels - almost 100lbs total for 16 to 18 conversion. What does that do to acceleration, suspension & steering wear?
In my driving (mostly street, some AX and track) I'm not finding I'm lacking traction but I'd like some more low RPM get-up-and-go.
Old Jul 21, 2015 | 11:54 PM
JParanee's Avatar
JParanee
I'm running
Pirelli
P zero Rossa
285 30 18 rear
225 40 18 fronts
Old Jul 22, 2015 | 08:00 AM
gnoy26's Avatar
gnoy26
very nice car
Old Jul 22, 2015 | 09:43 AM
Emo993's Avatar
Emo993
JParanee, how many miles, do you like them (wet/dry). Cornering etc. I'm in need of new tires, last ones were Hankook (cornering very bad). Mark
Old Jul 22, 2015 | 10:32 AM
rrc715's Avatar
rrc715
Default 95 C2 Manual
I am running
Pirelli Rosso Tires
Front 225/40ZR18
Rear 285/30ZR18
Old Jul 22, 2015 | 05:20 PM
JParanee's Avatar
JParanee
Just put them on a few months ago
Have not run them in the rain yet
So far the car is very sticky and feels very good
No steering quirks at all
Back end is stuck like glue now
Old Dec 31, 2022 | 12:49 PM
98:993-Cab's Avatar
98:993-Cab
4th Gear
Attachment 1229966
Attachment 1229967
Attachment 1229968
Love those wheels. I want to replace my twists. What Brand are they? Thanks, Claus
Old Dec 31, 2022 | 11:40 PM
Gbos1's Avatar
Gbos1
You need to drop that suspension looks like a truck
Old Jan 1, 2023 | 10:57 AM
71-3.0-911's Avatar
71-3.0-911
I don't think he can with those offsets. Looks like the rim and tire are well past the fenders.
