993 Forum 1995-1998
Valve Cover Gasket DIY Instructions
Old Sep 10, 2003 | 05:23 PM
adambos's Avatar
adambos
Talking Valve Cover Gasket DIY Instructions
Hi all,
I will be attempting to replace my valve cover gaskets, spark plugs, and oil this coming Sunday. I've found the DIY instructions for the plugs and oil, but does anyone have the DIY instructions for the valve cover gaskets? I've looked on p-car.com but can not seem to find them. Any help on instructions, tips, or things I should look out for would be great!
Thanks,
Adam
Old Sep 10, 2003 | 06:02 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Adam
Have you tried a search for "valve gasket?"
Coincidently, I found what I think is a minor vc gasket leak & did a search. There are several quite detailed threads covering everything you'll need to know from tips to tools, including your post asking the same question last month:
Originally posted by adambos
Hi all, I've done a search, but can't find DIY instructions on how to change the valve cover gaskets. Is there anyone that could point me in the right direction for some instructions or advice on things to look out for, and how long it will take? In terms of parts it looks like the set will cost $61, plus the cost for oil and filters while I'm at it.
Thanks for your help!
Adam
