Smoke, Burning smell, bad noises?
Well, I had convinced myself that the aux heater blower was probably the issue. But that was too good to be true. Following our man Tore's test instructions, (thanks, mpruden) the aux blower functions correctly. There is some difference in the settings of the ***** as to what starts when but the blower runs, except for one thing. I cannot detect any air movement, either suction through the intake trumpet on top or exhaust through the outlet flaps underneath. Maybe I don't know where to look. Is it possible that the fan has lost its vanes, that the noise and odor, now gone, was the shearing off and burning/melting of the all that plastic debris? Can it be, that the motor, now unencumbered, can run free but doesn't move air?
Mysteries abound,
-rb
Mysteries abound,
-rb
Seared
Mysteries abound,
-rb
Mysteries abound,
-rb
The blower motor assembly is very easy to remove - two 10mm bolts from the left, an electrical connector, and hose clamps. Two minutes, tops.
Andreas
Mysteries abound,
-rb
Mysteries abound,
-rb
Maybe try switching the aux fan on then put the car in reverse gear, you should feel the air blowing out the rear exhaust vents under the rear of the car if the fan is moving air
With all of the air being blown around, under the engine while it's running, I seriously doubt you'd be able to tell if the fan is working properly. Those flapper valves aren't going to emit a whole lotta volumn. Pull the ducting off and switch it on. You should be able to immediate tell if your internal fan blades are gone.
Actually overboosted, those flapper valves pump out an impressive volume and it is real easy to tell despite the noise and heat if they are on or not. However, the duct temp has to reach a certain value for them to come on (see Tores site). iirc, When I tested mine after replacing resistors, from memory it was about a 20minute drive, plus 5 minutes idling at about an 85 degree ambient before they kicked on. They dump out a LOT of very hot air. But I do agree better ways to test that fan have already been posted than the flapper test.
