Engine wiring harness
Anyone replace their engine wiring harness? Just curious how difficult the job was and if there are any DIY tips to be shared. I have searched the forum and mostly found threads discussing harness replacements done by the dealer as part of the recalls.
Done it but had the engine out and found it even easier once intake manifold and secondary air pump removed.
If your reasonably adept with your tools it shouldn't be a real problem ,it may do to lower the engine
for more access as well if removal isn't preferred.
I changed the entire engine shroud and alternator at the same time so it didn't take a lot more to get
the harness out in toto...Bert
