993 Forum 1995-1998
Optima Battery
Old Dec 6, 2002 | 09:14 PM
Greg Fishman's Avatar
Greg Fishman
Post
[quote]Originally posted by graham_mitchell:
<strong>Is Optima really the best option?
</strong><hr></blockquote>
Is there ever any one best option for anything?
The Optima is readily available in the US at many retail and mail order facilities, we know it fits and for the money it is a good deal.
Maybe it weighs a few pounds more than the options you listed but if you can feel a 5# or even 20# difference in your car then you are truely more qualified than most here. Besides the front end is not the best place to remove weight as it can just lead to more understeer.
Old Dec 6, 2002 | 11:35 PM
graham_mitchell's Avatar
graham_mitchell
Post
Greg,
I agree with your last point about lightening ONLY the front. However, for every lb or kg I remove from the front, I will try and remove double that on the rear to maintain and even slightly correct the original balance.
And I agree that I would not notice a 20lb reduction on its own, but this is part of a process of losing weight wherever I can and aiming for 150lb reduction overall.
Graham
Old Dec 6, 2002 | 11:56 PM
Greg Fishman
Post
If that light weight battery is part of a weigh reduction strategy I agree it is worth considering, your two to one ratio sounds like a good plan. A lighter car is one of the best performance upgrades you can do. I took about 300# out of my race car and the difference was amazing. Best of Luck.
Old Dec 7, 2002 | 01:18 AM
Jason R's Avatar
Jason R
Post
For those interested, I was at Costco (Bloomfield, MI) earlier today and saw the Optima red top for $105. Can't remember the model number.
Jason
Old Dec 7, 2002 | 09:28 AM
JohnM's Avatar
JohnM
Post
Hi Graham,
The Odyssey and Dyna-Batt batteies you list have very low capacities (16Ah for the Dyna-Batt). That will not be a problem if you are aiming at a track car and will have reserve starting batteries available, it is very likely to be a problem if you use the car regularly on the road. A few days with the alarm on will be sufficient to discharge to the extent the car may not start, and a few short trips these winter evenings with the rear screen heater on could also leave the battery in a precarious state. If you go with one of those it would be very advisable to have a trickle charger in your garage and connect the car to it every night.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
