Will an alignment solve my steering issues?
I went to Grand Motors in Montreal (thanks to Kacey for the reference). They did an alignement but the kinematic toe did not require too much adjustment. The tire pressure was also low.
The car handles way better now! Not perfect as I kind of felt the car was going to slip while driving fast in a highway entrance but maybe it's normal.
The steering feeling is much better and under control.
As the shop suggested, I will replace the control arm bushings with FD's and I should feel an improvement.
Now, to your specific question, I don't think it gets totally out of hand until you're about 1/2" above RS specs. Even then, years ago I got a hold of one of the first 964s out here in the Bay Area to do some shakedown work on. Absurdly low. We were still able to run the car on the track record. Ultimately, just depends on how comfortable you are working it. On the street? More likely crappy roads with proper ride height will be more annoying.
One caveat is that stupid low leading to bump steer + bottoming the suspension is a nasty that I don't think anyone here at our (lack of) skill level can regularly survive.
Two days ago I noticed that the rear wheels are not similarly distanced from the rear wing. I thought it was an optical illusion, but it soon become clear it's not.
In addition, on the wheel that does not seem to sit properly, the ride height is also lower, so much so that for certain bumps the tire rubs against the inner wheel arch.
I have measure the distance from center hub cap to center hub cap and there is a 3.5 cm (~ 1.38 in) difference between the right side vs the left side.
I'll take the car to the shop, but until then a few questions because I am in a maximum panic attack mode:
(1) Does wheel alignment also affect ride height in any way?
(2) Is it possible that just from wheel alignment you can end up with a 3.5 cm difference RS vs LS?
My current theory is that eccentrics have not been properly torqued when doing the alignment. In fact, the mechanic told me that he hadn't tightened them hardly because he anticipated that further fine-tuning would be required.
I didn't however expect him to torque them so that they may actually move.
I appreciate any feedback. I was quite stressed initially because I thought the car might have been in a major accident, but the fact that (a) the alignment was ok at first; and (b) there is no sign of major accident have helped me relax a little bit.
3.5cm seems like a lot! I would guess it should be in the order of a few millimeters...
FYI, when I first installed my BBS LMs with 285s on the car, I was not running enough negative camber in the rear for such wide tires. As a result, only the driver's side rubbed a few times (upper right corner of the inner fender lip, when facing the wheel center cap)...
It took serious road bumps to rub. It rarely happened, and never did any damage to the paint... We're talking 1mm by 2 inches long black mark on the inside of the outer lip!
After replacing my front bushings, I decided to completely change the front and rear alignment values, to modify the behavior of my car.
The result: the car better matches my driving style, and as an added bonus, an 1/8" decrease in camber in the rear also made the rare occasional rubbing disappear!
In short: I suspect there is indeed a slight alignment offset...
As far as the initial post. From experience, alignment values aside, the front LCA bushings have a great impact on the steering feel. At almost 20 years old, they are most likely to contribute to the vagueness one would feel at freeway speeds...
As I installed new Rennline subframe bushings I had everything taken out, sand blasted and then electrostatically painted.
To do this, the components had to sit at 200 degrees Celsius for about 30 mins. Given that in order to slip in a new bearing you need to do the same, I would have thought that it's safe, but who knows.
Although if they had deformed I assume that they wouldn't fit together as perfectly as they did.
This is very intriguing as basically they can shift the entire rear axle around.
I haven't been able to find any instructions in the service manual on that - under section 42 it only says that the crossmembers do not need to be removed.
Unless I receive some clear advice, I would incline to fix both rear subframes in such a way that they are equally distanced from a clear reference point (e.g. front control arms).
Any thoughts?
CORRECTION: the bolts are NOT eccentrics, but the Rennline bushings have an oval hole that allows room for adjustment.
CORRECTION 2 (because the mechanics have provided yet more inaccurate info): the hole in the bushing is round, but the diameter of the hole is 16 mm, whereas the diameter of the bolt is 12 mm (as per the actual bolt and Porsche's parts manual). Therefore, there may be some room for adjustment.
Any thoughts?
The Rennline kit should have come with the required bolts. It's only the top "hats" that have the larger holes. The subframe mounts/bushings are the correct size and the mount should not affect where your subframe was mounted. Any amount of "play" would be negligible and surely not noticeable to the eye.
