Wideband O2 integration on 95 non-vram
I'm planning on running an innovate motorsports dlg-1 dual wideband kit with my fabspeed exhaust setup.
The innovate kit will send a simulated and programmable narrow band signal to the ecu, so that's nice!
However I have a question for you guru's. If I eliminate the exist O2 heater wires, will the ecu throw a code or go into limp mode? I know I can insert a resistor to fake out the ecu unto thinking it's supplying heater power... But if there's no diagnostic readbacks from the heater circuit, I'd just as soon pull the wires.
Thoughts?
Thoughts?
