Dreaded Immobilizer Control Failure
Ladies & Gents just had the dreaded immobilizer control unit failure. C4S with 105,000 miles original owner. I suggest everyone set aside $2000 for this pleasure sooner or later.
The immobilizer control unit controls the key entry, alarm and blocks access to start the car. When it fails you cannot start the car at all. There is no way to reset it as the immobilizer control unit stops communicating to the main ECU of the car and everything else. The crazy 10 step process to reset the alarm key code is not even accessable.
Flatbed to dealer & order $1400 part, remove drivers seat replace control unit.
of system elements besides the immobilizer which will prevent the vehicle from starting.
1. bad blub
2. bad wiring to bulb
3. bad ignition switch (rear part)
4. bad connections in clock where bulb is located
5. bad immobilizer wiring
This gave me fits tracking things down...but I eventually got there!
