993 Forum 1995-1998
HELP!!!........sunroof woes
Old Apr 14, 2015 | 09:57 AM
Ridin Dirty's Avatar
Ridin Dirty
Default HELP!!!........sunroof woes
Nice day here in the northeast yesterday. 993 running beautifully so naturally opened the sunroof....good times! Well the 993 liked it being open too b/c now it won't close/stuck open
May I ask for an opinion of diagnosis so I can determine if it's something I can sort or plan a stealer visit?
Observations:
1. switch probably not the problem (I think) b/c when depressed I can hear a click up at the sunroof as though a motor was trying to be actuated. So there is a signal being sent from the switch.
2. it has been temperamental for a year or so. I would have to depress the switch a few times in a coaxing sequence to get it to work; only in closing....it always opened no problem
3. no motor sound just a clicking with each switch depress
Thanks in advance and appreciate any advice (I know don't drive in the rain )
Old Apr 14, 2015 | 12:42 PM
996scott's Avatar
996scott
This may be your problem. mine was doing the same think and found the broken part when I unzipped the head liner.
https://rennlist.com/forums/993-foru...of-before.html
Old Apr 15, 2015 | 09:47 AM
Ridin Dirty
Thanks!
I pulled the liner down, hit the motor a few times/jiggled the wires to it and now it works; but i have a feeling it's going to stop working again.
Strange that means cables are okay, motor works, no obvious signs of damage, but its temperamental.
Old Apr 15, 2015 | 11:03 AM
sand_man's Avatar
sand_man
And while we're discussing sunroof "woes", can I just say for the record, how much I despise that sh_tty felt seal around the perimeter!!!! UGH! DIE!
Old Apr 15, 2015 | 12:46 PM
eichlerman's Avatar
eichlerman
Last year my sunroof also stuck in the open position. During the diagnostics I noticed a slight twitch at the motor when I pressed the switch indicating a good power circuit. I removed the sunroof and inspected the tracks, gear and cables. I found no mechanical issues but the lubrication on the tracks was very sticky. It’s a very simple system that is susceptible to failure if the sunroof panel does not slide freely. There are no limit switches so the motors are sized to provide adequate power to open and close the sunroof, but not damage the system or car structure at the end stops. I suspect there’s a slip clutch in the motor. The friction in the track can increases over time as the lubrication degrades to the point of engaging the clutch. With continued use in this state I suspect we start abusing the motor and switch resulting in eventual failure.
I recommend periodic removal of the sunroof panel for inspection, cleaning and re-lubrication of the tracks and gear. The cables are suspended in felt so they need no lubrication. They task is actual pretty simple.
Old Apr 15, 2015 | 05:29 PM
Ridin Dirty
Excellent.....seems logical and likely what I'm experiencing. I'm a bit afraid to attempt to remove the roof though. Any way I can lube whilst the roof is still in place?
