Dual Distributors
. Anyway, when I was going through everything to find why I was down on HP I also noticed that the upper distributor feeds the exhaust side and the bottom feeds the intake. This seems backwards to me and I checked my C2S and it is the other way around. I am having trouble finding a good schematic or description as to whether this matters since, as best as I can tell, they fire simultaneously - no delay between the two. I know I put this back the way it was before I dropped the motor as I have pictures showing this. Therefore, I can only assume that it has always been like this. Any one have any experience with this or comment?
https://plus.google.com/photos/11229...00983582700321
NOTES on Marking and Numbering
a. Distributor caps have markings for cylinder numbers
b. Cylinders are numbered 1-3 on left, from back to front;
and 4-6 on right from back to front.
c. Spark plug wires are marked I-x and II-x where is x is from 1-6.
“I” refers to the upper spark plugs, “II” refers to the lower spark plugs.
d. The lower distributor cap is for the upper spark plugs (I) and the upper
distributor cap is for the lower spark plugs (II)
