993 Forum 1995-1998
993 Turbo PPI
Old Feb 25, 2015 | 06:52 PM
Rxinside's Avatar
Rxinside
3rd Gear
Default 993 Turbo PPI
Hi,
I've got a PPI on 993 TT I intend to buy, but I have a hard time determining if the deal is worth it since the asking price is quite steep and I do not know what to expect to resolve those issues. I'm mainly concerned about the oil leaks.
the under hood light is inop .
one bulb out in the third brake light
30k service should be done .
air bag maintenance
brake fluid flush
rear wiper is too long should be replaced
left front driving light is broken
four tires are too old . dating back to 2006
slight oil seepage around right side turbo
slight power steering leak around resevoir
I am also going o be sending you via e-mail the ppi report and warranty data on the vehicle .
The paint and the interior are in excellent condition .
Any advice?
Old Feb 25, 2015 | 07:05 PM
stace's Avatar
stace
nothing sounds very serious beyond the leak around the turbo. might be good to understand what is involved there. I'm not sure what air bag maintenance means. I'm not aware of routine maintenance for airbags... otherwise it all sounds like typical maintenance. good luck and be sure to post some pics if you buy the car!
Old Feb 25, 2015 | 07:09 PM
TMc993's Avatar
TMc993
Items 1, 2, 3, 5, 6, 7, and 8 should be relatively easy to price out and resolve.
Not sure what item 4 (Air bag maintenance) is.
Items 9 & 10 are worrisome and potentially expensive. I'd be wanting to know a lot more about these two.
Old Feb 25, 2015 | 07:10 PM
LexVan's Avatar
LexVan
Typical. Always figure at least 10% of the selling price to "sort out the car" to your standards once you take ownership. Price of admission. Negotiate, negotiate, and then negotiate some more.
Old Feb 25, 2015 | 09:33 PM
oLuB8UchKxp's Avatar
oLuB8UchKxp
Might want to do a leakdown test too. Also have them check the suspension, motor mounts etc.
Turbos leaking might mean a rebuild at some point. You can always go to k16/k24 hybrids =)
Old Feb 26, 2015 | 02:11 AM
quacktoduck's Avatar
quacktoduck
i had problem #10 for me it was a loose clamp at the power steering pump.
cant say much but get a good PPI. mine showed that i didnt have any issues with the trans and strong motor but 3000 miles later im doing a LWTFW and clutch.
Old Feb 26, 2015 | 02:44 PM
uicnick's Avatar
uicnick
I would say textbook typical 993 and 993 turbo issues. Nothing to worry about. Turbos leaking does not necessarily mean rebuild in my experience. None of those items sounds major. I reduced my oil level in the sump and found a slight mar in an o-ring at the turbo oil supply bridge on my right side turbo. After addressing the o-ring and reducing my oil level, my leak went away as well as high oil consumption.
Old Feb 26, 2015 | 03:23 PM
pp000830's Avatar
pp000830
Default Issue list
Make sure the air bag light is not an air bag deployed incident. The attached list may help you ask what has been done and what needs doing on the car. The list is for a Carrera but most all of it applies to a Turbo as well:
File Type: pdf
Old Feb 26, 2015 | 03:24 PM
DiegoR's Avatar
DiegoR
9 could be a timing chain gasket gone (mine had that issue)
10 could be any loose hose clamp or like mine, a power steering hose that has a internal valve perhaps that's what is leaking a bit.
