Retain Driveability codes with battery change
This could be the trick for those that need to swap out a battery and still maintain drivability codes. don't own it myself, but I've wasted larger money on dumber things.
rob
E-Z RED (EZRMS4000)
Super Automotive Presets & Computer Memory Saver
http://www.tooltopia.com/ez-red-ms4000.aspx
rob
E-Z RED (EZRMS4000)
Another option is the 9v battery that plugs into the cigarette lighter tool, much cheaper. I've never used it, for some reason I don't have to reset the readiness flags when I remove the battery, they stay set.
Yep, a 9V battery with a cigarette plug will do the trick....or, if you have a spare 12v. battery of any size in the garage, hook it up to the cigarette lighter with your Battery Tender leads. Just be sure to get the polarity right.
Or if you also need a battery maintainer get the CTEK 7002 which has a supply mode as well ( most likely other brands do this also). Usually about $105 or so if you shop around.
