removing the key shank from the key head?
http://p-car.com/diy/key/
this describes that there is a catch in the key housing. Can you find a spot to relieve the catch with a tool and let the blade fall out?
Thanks guys. That helped. I knew there was a catch in there, but it wasn't obvious how to diffuse the bomb
For good karma, here's the illustrated guide to key shank removal
Step 1: using a tiny screwdriver or blade, pry the spring stopper up (perpendicular) from the key face
Step 2: allow the spring block to slide out
Step 3: the shank is now free to slide out from the key head
Hope this helps someone else in the future
