993 Forum 1995-1998
Rear Lights
Old Sep 3, 2002 | 02:11 PM
Richard C2S's Avatar
Richard C2S
Post Rear Lights
I noticed over the weekend that there is some moisture in the rear, center light fascia, the one that is just below the engine lid and includes the back-up lights. After removing the tail lights, I had difficulty with one of the three fasteners that holds the fascia in place.
Anyone out there have the moisture problem and any suggested remedies?
Richard
Old Sep 3, 2002 | 02:33 PM
STLPCA's Avatar
STLPCA
Addict & Guru
Post
Richard
An excerpt from <a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic&f=3&t=002085" target="_blank">"Moisture in rear light bar "</a> in the archives:
Although not a widespread problem, it is frustrating when it occurs. The problem is water entering through gaps in the light unit seals. If not corrected the accumulated moisture can cause mold, discoloration or damaged reflectors in the light assembly. Despite pressure washing my car I have had no difficulties, so a good tight seal is possible.
A "fix" was described by "Allen - '97 993 coupe" in his old Board post:
Posted By: Allen - '97 993 coupe &lt;shelleya@squared.com&gt;
Date: posted 4/25/01 at 2:00 p.m.
The previous owner of my car had the entire rear lense replaced because condensation continued to collect in the area you mention. The problem occurred in the replaced lense as well. If you have discolored molding inside the lense, you will have to remove the assembly, then the bulb to gain access to the inside area, the somehow clean out the mold.
Since I was aware of the problem when I bought the car (it had no molding in it at the time), I have done (2) things: 1 - I removed the entire taillight assembly and used silicon to seal any "gapped" areas when water might enter and cause mold. 2 - I have just tried to be careful when washing the car, trying to minimize the amount of water flowing over that portion of the lense. This has worked for me as I have no condensation problem at all...however, I also never drive the car in the rain either.
