Bergvill LED install ?
#46
All of the front lights are working fine. I'll check the fuses and voltage in the sockets and report back!
#48
So the latest is that fuse 41 was indeed blown, but when I replaced it, it blew again when I turned the lights on. I replaced it two more times and the same thing. I also tried taking out all of the LEDs in the rear and putting back in the old bulbs, but no luck.
A buddy of mine is coming over with his voltmeter later so we'll check that and see if we can diagnose it.
Frustrating as all the lights were working fine before I did the upgrade...likely installer error!
#50
great product
I've done the complete light conversion including the additional brake lights in the foggy holders. Fantastic results and worth every penny. Installed it in stages and I think I lost the CC when the festoons for the frunk and rear deck were replaced. Too lazy to pull them out and retest.
I didn't like the angle of the festoons at first as noted before so I removed the lens housings and twisted the right angle contact until the LED festoon laid flat when inserted. Problem solved.
I'm also interested in a HID or LED replacement for the high beams. On my motorcycle I used a LED solution for a straight up replacement for Low/high H4 at 3800 lumen. Best $65 spent on the bike and it is really, really bright. Thinking of modifying the front fogs to utilize their H3 solution.
Here is the site, no affiliation, yada...
http://www.cyclopsadventuresports.co...ulb-_p_83.html
Thanks Tore!
Thanks Tore!
#51
Anyone have part # for the LED bulbs. I bought some, installed them and they didn't want to work. The low beams seemed to work so I kept those and returned the rest. Must be a specific bulb type that I need to purchase. Couldn't see any reason why they wouldn't work, they went in fine just wouldn't light up.
Thinking I will keep the H1 high beams and run with my new LED low beams which are very nice.
Anyone have similar experience?
#53
Odd, I thought the LEDs drew less power. All I know is I installed them all, turned on the light switch and nothing happened. I will check the fuse and perhaps try again.
#56
Noodle Jr.
Thanks Tore!
Thanks Tore!
#57
The fog lights share fuse with the reverse lights so if the fuse blow and is of the corect Amp there could possibly be a short in the reverse lights but that is pretty easy to check!
#58
