993 Forum 1995-1998
Does photo show ride height reference points?
Old Nov 18, 2014 | 09:54 AM
Ron's Avatar
Ron
Default Does photo show ride height reference points?
Do green dots in photo show ride height reference points? Another set on other side of car.
Old Nov 18, 2014 | 10:31 AM
mpruden's Avatar
mpruden
Yes, specifically it's the green dot on the top of the photo, not the one toward the bottom.
More info here.
Old Nov 18, 2014 | 02:41 PM
pp000830's Avatar
pp000830
see attached
Old Nov 18, 2014 | 05:34 PM
Ron's Avatar
Ron
Thanks for information.
I’m going to be purchasing new tires and have car suspension alignment but I first wanted to check ride height using factory reference points. I have set of factory work shop manuals so I have as fair amount of data.
I have H&R coilovers.
Also wanted to check ride height by measuring from fender lips to floor too.
First measured lips to floor in inches:
left front—25 1/2”
right front—25 1/2”
left rear—25 1/2”
right rear—24 7/8”
Measurements from factory reference points:
left front—130.3 mm
right front—132.4 mm
left rear—112 mm
right rear—113 mm
Car measured level with level on sill.
Old Nov 21, 2014 | 05:58 PM
Ron's Avatar
Ron
More info here.
Is it more accurate to measure ride height using reference points on the chassis?
Old Nov 22, 2014 | 09:01 PM
il pirata's Avatar
il pirata
Yes.
