Need help sourcing a part
For folks that have Motons or other aftermarket shocks, what did you do for front brake lines?
With OE shocks there is a bracket to support the joint where the flex line joins the hard line. Motons don't have this support, and I don't like having an end of the hardline unsupported.
Does anyone know of an off the shelf brakeline to go from the chassis directly to the caliper (bypassing the hardline). I know I can have custom ones made, but hoping for an off the shelf solution...
(In case I have to go the custom route) Anyone know the fitting sizes? This metric pipe/tubing thread confuses me...
If no one pops in later on, I'll look at the yellow car in the AM when I'm back at the shop. I honestly don't remember.
What I've done in the past with torsion bar housings that don't have them (RSR struts?), is fabricate a bracket. Of course you're not going to weld anything on...... But a fabricated bracket attached with strong hose clamp(s) has been sufficient for what I've done. I also remember one time at the track I discovered them just flopping around when he was changing tires. Used some Big *** tie downs in an X pattern to fasten them to the strut. 3-4 years later the guy still had my ER setup on the car.
The other factor is: I'm switching to caliper studs, so the hardline has to go.
Is it possible to cut the bracket off your old strut and use a stainless steel hose clamp to mount it to you new strut. Or buy somthing like this;
http://www.eeuroparts.com/Parts/3286...FcJQ7Aod_EgAzA
or this:
http://www.bbclassicsinc.com/product...amp-universal/
or this:
http://www.summitracing.com/parts/rus-683942
or this:
or this:
OR spend time in fabricator hell making your own. (Made too many -3 lines back in the '80s. Amazed we never lost a car.)
And those other links point to stuff I sure wish was commercially available back in the Olden Days.
Mine have a fabricated part, held on with upper and lower hose clamps. I don't have memory of doing it myself, but it's very similar to what I would have done on customer cars in the '80s.
If you go that route, the clamps look easy enough to loosen. So if you go to studs on the wheel carrier, you'd just have to deal with a couple of twists to those clamps. (Other thought is that if you've got the calipers off to change rotors, you'd be bleeding brakes anyway. Several ways to make fluid leaks/bleeding hassle minimal if you end up cracking the lines open.)
