DIY front brakes?
RL Technical Advisor
The 993 brakes are about as easy as it gets. Dual bleeder screws makes bleeding a snap too ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I just use some groove-joint pliers to get the spring clips open and a small pry bar to get the calipers back in place, using the pad backing plate as a pry point. I don't think I have ever owned a car where I could swap pads out faster.
An easy job.
Can someone recommend a decent Bluetooth radio head for a 993 to replace the alpine 7807? Prefer something with ***** for volume and tuning.
I hear some rubbing sound coming from my new pads. When I installed them I wondered what causes the pads to retract after application. What should I look for?
