Anti Lock and Check Engine Light HELP
4th Gear
Anti Lock Brake light comes on and stays on while on the freeway then the Check Engine Light comes on and goes off. The car feels as if it is turning off for a slit of a second. '97 993 83K. Any help will be greatly appreciated.
Received 5,402 Likes
Do you have a spare DME relay?
Ask a mod to move your post to the 993 forum for more faster help.
Battery connections and DME relay are easy and cheap first things to check
after that it gets more expensive
these cars are getting long in the tooth and electric issues are showing up in the DME itself
cold solder failures
disintegrating plastic parts
etc
If all else fails, It might be worth while to send the DME to a re-builder like Specialized ECU Repair
etc
another cheap thing to check is the sensor connection on the wheel carriers. plug might not be in all the way, or maybe the little allen screw on the rear is loose and the speed sensor wobbles out slightly.
