Fabrication of a DME relay jumper
Constructing as the title says...
I am thinking the use of a fused, 12 gage wire, with blade connectores at each end.
So what amperage fuse should be utilized?
P.S. This is an emergency fuel pump operation jumper; and yes I do carry a spare DME relay.
Thanks in advance, gentlemen...
From the workshop manual...
"Pull DME relay (R53) off the Central Electrical
System and use a fuse-protected shopmade
jump lead to connect pin 30 to pin 87 b
(identifications 3 and 7 on Central Electrical
System). The fuel pump should now operate."
Hmmm...when I made my emergency jumper I did not put a fuse inline with it. I would say that one would want to use a fuse equal to the rated current of the fuel pump. I have no idea how much current that is.
Mine looks like this one, no fuse. I have not gotten around to it. Here is a pic and instructions for its use:
http://www.clarks-garage.com/shop-manual/fuel-05.htm
The one I made is actually an immobilizer bypass for no-crank situations, and is a simple piece of wire with a male spade connector at each end. For the DME, I only carry a spare relay, not a jumper.
I carry both a spare relay and 3-wire jumper...No fuse on the jumper since it's only used to confirm that the relay is bad (I've used it once for that purpose)....I would think that if you wanted to use a fuse on the jumper, you would just fuse it like the 15 amp fuse on the fuel pump circuit...No?
Agent Orange
Thanks!
Edit: I was mistaken about the effects of bypassing R61. Jumping this relay will let the car crank, but will NOT allow it to start. Not sure what that does besides wear out the starter...
Yup! I've not had immobilizer trouble, either, but when my DME relay gave out during a lapping session, it sure was great to have the spare handy. Having this little wire assy aboard may come in mighty useful someday.
Paul902,
This is what I was looking to make...Is the wire 14 gauge? I was thinking of adding maybe a 15A fuse between spade ends.
Thanks for posting a photo!
...and yes, I do carry a spare relay.
I'd pick wire gauge to match the crimp spades, even 22ga can handle pump current in an emergency
Isn't the circuit already fused?
I have one just like the picture but putting a label with the relay contact #'s on is a good idea
In Vorsicht's link it shows a three terminal jumper, rather than my simple two terminal jumper. As noted above, I could run the fuel pump (with it with the engine not running), and nine9six references a two terminal jumper from the manual. Anyone know offhand what the purpose of the third jumper terminal in Vorsicht's link is, or is it superfluous?
