How to remove rear interior quarter panel
OK, This seems like it would be an easy thing to do. There are visible screws but after removing them, I was still unable to take the rear interior quarter panel off. Is there a trick to this? Can someone tell me how they removed theirs? Thanks.
Another method is to push down on the leading edge of the panel, while pulling out the lower front edge. The bottom half is pretty flexible, and upper is a little tougher. You are then rotating the panel around that back mounting point. The only advantage to this is that there is no removal of the rear panel required. Installation is the reverse, but not that tough (unless you have a rollbar in the way).
