New fan and alternator
Researching prices on a new fan and alternator. Seems the best price on the fan is www.eeuroparts.com for $472 (with fan hub already installed) and the alternator at www.autohouseaz.com for $203.89 (plus core charge of $150). Both parts are Bosch. Anyone ordered from either of these that can provide pros/cons or suggestions? TIA
I wouldn't recommend exchanging your alternator, the rebuilt ones don't use the same level of quality components as the original. You can rebuild yours or farm it out to an auto electric shop.
Unless you've had a substantial failure, your original alternator can be easily rebuilt with a handful of parts. Heres a parts list for the alternator in my 95;
http://www.woodauto.com/Unit.aspx?Ma...Ref=0120468125
You'll need front and rear bearings, voltage regulator with brushes, and likely a rear bearing tolerance ring (its plastic and falls apart). I bought good SKF Explorer bearings from a local bearing shop, the voltage regulator from Pelican, and the tolerance ring from a local auto electric place. You may need to have your slip ring cleaned up if its grooved; I had mine lightly cut but I could have got away with a hand polish.
Heres a good DIY if you want to take it on yourself;
http://forums.pelicanparts.com/porsc...r-rebuild.html
The best I could find on a new fan was $463, PM me if you want the source as I don't want to post it incase it's against the rules.
I bought a rebuilt alternator but I just paid the core charge. I didn't want to trade in the original alternator. I am probably going to have it rebuilt at some point so it will be ready when my "new" one fails like others have said.
My original alternator works great. However, when I went to remove the belts, I found the 12 point connection on the end of the alternator shaft was completely stripped. I really didn't want to replace the alternator, but I don't think this can be repaired.
Ouch! Just brainstorming...you could drill out the shaft and have a stud with flats on the outer end welded in...or, someone with a RS pulley chime in here, does that setup allow more threads of the shaft to protrude? If so, go RS pulley and file the end of the shaft square so that you can fit an open end wrench on it.
I've ordered parts from AutohouseAZ and it's a very decent company that's been in business for a while. They tend to sell OEM parts and the prices are usually very good.
Agent Orange
My old C4S had a chewed up triple square bit on the alternator. So I just wrapped a large screwdriver in cloth, stuck it between the blades to prevent the fan from moving and then used the 24mm box wrench to loosen the nut. No issues using that method, I've done it several times since.
Back to the post, I've decided to buy a new alternator and fan (and fan bearing) just because I feel the age of the vehicle warrants replacing. Thanks for all the help.
Technical Guru
