Alignment in Los Angeles?
Car pulls ever so slightly to the left. Any recommended shops in the Santa Monica area to do a 4 wheel alignment? Should I do a corner balance as well?
TIA.
TIA.
Steve can certainly do a great job for you on the alignment. He has done my car in the past. Don't expect miracles on the corner balance. The rear shocks are not threaded, hence the perches (height) cannot be adjusted without actually changing the springs. I was told, although I have never seen them, Porsche has three different sizes of shims/spacers that can be, or have been inserted in the springs to play with the rear height a wee but.
The front spring perches have limited adjustment for fine tuning a weight/ corner balance.
Steve Alarcon is the man...it is always the best when he works on your car, in my opinion.
Originally posted by Hubert
I"ve gone to west end alignment in the past for cornerweighting and alignment; Darrin takes his time. Might want to look them up.
