I just bought a new battery, and upon removing the old one I found about 2 tablespoons of white powder in the battery compartment. Is this dried acid? What is the best solution to use to wash it off? Anyone encounter this?
I had a worse thing happen in my car, the battery acid etched portions of the trunk pan. <img src="graemlins/cussing.gif" border="0" alt="[grrrrrrr]" />
You can check out my battery setup first hand tomorrow.
Also, i noticed at the local kragen auto parts, they had an exide orbital select on the shelf, if you are interested. I know, you've been through a bit of a saga with batteries..
Had the problem with my 944 when battery acid leaked and etched the metal. I cleaned the area with baking soda and then sprayed a rust proofing paint. Lastly, I purchased a battery pad that absorbs any future acid fumes that may escape. Been about fours years and no more problems. When I replaced my battery on the 993, used another battery pad and made sure vent tube was properly in place.
Well today I put some baking soda on the powder and dripped some water on it and it fizzed Looks like acid! So I pored Whole container of baking soda on the whole trunk area and washed it real good. Installed the new Interstate battery with a vent that is in the wrong location, (anyone know how to adapt this?) And the battery would not start the car! I charged it for a while and it was still dead! I ent up putting the old battery back into the car.
