993 blower fans wont turn off
I noticed this issue starting yesterday; the blower fans wont turn off when the car is on unless I push the leftside of the HVAC controller in or tap it with 2 fingers then it stops?
Maybe you should have a look at the connections behind the CCU.
Usually hvac issues are related to the blower relay (fuse box to the left of the rear trunk). Or the blower resistor or temp sensor. But since you say it stops when you tap on it, that's why Im suggesting to check the connections.
And before tore repli to this thread, you will find lots of useful info here.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
http://www.porschehvac.bergvill.com/
Exact thing happened to me last month. Took the CCU out cleaned the both the connectors and voila! Problem solved
