Halon 1211 fire extinguisher
Just wondering if the 2.5 Pound is still the Preferred Extinguisher for our cars?
If so, Can the Older Units still be Serviced?
Thanks Tom
Thanks Tom
I'd rather use Halon than dry chemical-that white powder is murder to clean up-maybe better to let the car burn, than clean it up?
Contact your local fire extinguisher service on the question of updating.
Just thought I would mention that "Halon" was banned in 1994 as it was responsible for ozone depletion in the atmosphere and also toxic to humans when used in confined spaces (computer rooms). The replacement is called Halotron. As such, a halon extinguisher cannot be refilled with Halotron since the contents of the extinguisher would not match what's on the label.
HALON 1211
ThANKS Ed
Halon 1211 is a 2.5 pound fire extinguisher - Hand Held model with a Sprayer Nozel for cars.
I have read they are ideal but there are / is the issue of environmental concerns.
I have been told this unit will not destroy our paint if the car were to have say an engine or electrical fire.
A few years back some racing and DE Members here on RL were recommending the halon 1211
Now I would like to know what is being recommended ?
The \halon 1211 is still available for purchase on ebay.
I wonder if it can be serviced in the united states?
I believe it can be refilled but not with Halon.
Most good-sized fire extingusher service companies can legally recharge your extinguisher with reclaimed HALON. They should give you credit for any HALON remaining in your extinguisher and only charge you for what they put in. Depending on the age of your unit, they may require a pressure test, new o-rings for the valve, etc. Yes, it's expensive but miniscule compared to the damage a CO2 unit can wreak on your vehicle.
Halon 1211
Can u suggest or name a firm who can Service an Amerex Halon 1211 unit?
Sounds like this would be the way to go, depending on costs.
These units are on Ebay for $155
Thanks Tom
Thanks Tom
I started a thread on the racing board a few years ago. Check it out.
https://rennlist.com/forums/racing-a...questions.html
Halon 1211
Hello Mark
Thanks for sharing!
Thats one heck of a Read - wow! That article Hits Home!
I will take some time to consider all of that - I am a Newbie But...but I will also look into Safecraft System amongst the Many Others being discussed.
An acquaintance is offering me the Sensor type 1211 with a bracket - I think I will take that One to start. Hopefuly that enables me to qualify for DE?
Or atleast I have a Mounting point. Then find another Extinguisher with a Nozzle type sprayer - next to discover about Safecraft vs Halon.
Being in the great white North and enduring the coldest winter ever I too have to rationalize some of the same coinsiderations you do.
Regards
Tom
Thanks for sharing!
Regards
Tom
Halon 1211
hi Ron
Let me look into this - I have not heard of it till you wrote it here And after Reading Mark's Contribution.
Thjanks for sharing!
Appreciated
Tom
Appreciated
Tom
