Battery hold down adapter with no drilling car?
Is there a battery hold down adapter that does not require the drillin go holes in the car.
Are you using a non-stock size battery? If so, I just make a base to bolt in the stock hole out of 1/4 inch Acrylite plastic from TAP. Then you can drill the plastic for any tie-down you want to use.
Would it be possible for you to post a photo of your base?
