993 Forum 1995-1998
center tray removal
Old Aug 8, 2003 | 03:45 PM
Jonathan C's Avatar
Jonathan C
Default center tray removal
There must be a simple answer to this! I've tried using an offset screwdriver and a tiny, racheting wrench-like driver, but I just can't seem to loosen (or tighten) the phillips head screw located at the base of the hand brake lever. What a place to put a screw! It's a very tight fit, but surely something must work to remove or retighten that screw.
Do I just need to try again with a little more patience, or perhaps I need an even smaller/better tool? Or is there some easier secret?
Thanks for any help!
Jonathan 1997 Carrera
Old Aug 8, 2003 | 03:51 PM
poorb0yw's Avatar
poorb0yw
I used my VERY small ratchet from Griots garage (the one that comes as a set in a little red box) without problem.
Old Aug 8, 2003 | 03:54 PM
Jeff 993TT's Avatar
Jeff 993TT
I've just used a screwdriver without problems.
Another alternative ( similar to Griots, but much less expensive ) is to buy a small rachet at Radio shack ( about $10 ), or you can get a racheting 1/4" box wrench from Sears, Osh, etc and then stick your screwdriver bit into it.
Old Aug 8, 2003 | 04:47 PM
Moose's Avatar
Moose
I bought a flexible shaft screw driver at Walmart for $10. Works great.
Old Aug 8, 2003 | 05:03 PM
viperbob's Avatar
viperbob
Former Vendor
#1 philips works fine for me...
Old Aug 8, 2003 | 06:26 PM
EricGT3's Avatar
EricGT3
Better tools always help. Maybe spray some WD40 on it to loosen it if it won't budge.
Old Aug 9, 2003 | 12:52 AM
Jonathan C's Avatar
Jonathan C
okay...I figured it out! All along I've been sitting in the driver's seat, trying to unscrew the offending screw from a frontal approach. Even with the offsets, that just didn't cut it. But when I jumped into the passenger seat, lo and behold, I realised I could just slip a regular screwdriver in from that side. No problems...it couldn't be easier.
Moral: I guess this is a good example of getting so caught up in one approach that I failed to consider another, simpler angle.
Old Aug 9, 2003 | 12:59 AM
OldGuy's Avatar
OldGuy
Jonathan you should not ask these questions without
sharing your upgrades! I.E. whatcha putting in!!
Carbon Fiber, aluminum, **** carpet??
OG
Old Aug 9, 2003 | 03:19 PM
Jonathan C's Avatar
Jonathan C
OldGuy - nothing as wondrous as that. The tray was loose, and I was merely trying to tighten it. When I finally removed the tray for cleaning, though, I did find 12 cents in loose change underneath to put towards my next upgrade! In a prior car, I once found several dollars in change beneath the shifter cover. --Jonathan
