ESCO jack stand - How do you get to top rungs?
I just got a set of ESCO's, and Cactus pointed me to his DIY on getting the car on 'em by jacking the rear first from the engine, then the front by the front pan. I tried jacking the front with this method and I really like it compared to the method of doing one side at a time with the jack at the rear jack point. However, I could only get the fronts onto the lowest rung of the ESCOs. I want to go higher. A lot higher.
Has anyone perfected a method to get to the top of ESCOs that does not involve jacking up one side and then the other? |
I alternate between the engine and front pan. I usually go as high as I can on the rear (2nd stop) while still allowing my low profile jack to slide under the front. Then I go to the 2nd stop on the front. Wash/rinse/repeat one more time until all stands are maxed out.
There may be other ways, but that has worked well for me. |
you want to do this in stages, if you have it too high and lower the jack you may compromise the balance/positioning of the stand, which would/could be bad for sheet metal. YMMV
I use the common method to get all four stands in place (tires sat on pieces of 2x4, then jack rear and place stands, then jack front and place stands) then if I need to go higher I have built a (robust) platform to sit the jack on and I repeat back and front to get to the top setting of the esco's. Once it is already on the 4 stands, just lift in small increments to avoid larger angles potentially tipping the car off the stands.
Sorry to hi-jack but i have somewhat of a similar issue.
When i lift rear by engine case, Escos don't fit under the rear jack points? Maybe need another inch or so. Any recommendations besides having a taller floor jack or putting a block of something on the floor jack plate (or whatever it's called). Jack goes up 17 inches i think, but because the engine case is behind, the jack points dont get high enough. |
Originally Posted by NYC993
(Post 11499446)
Originally Posted by mpruden
(Post 11499496)
I don't think there's anyway around it. You need a jack capable of higher lifting, or you need to find a way to add some kind of spacer to your jack, either between the floor and jack, or between the jack and car. As always, be safe with this kind of stuff. Spacers make me nervous, personally.
(Post 11499446)
Thanks for the info here, guys. So, one end at a time, notching it up a position at a time should be a good method. John mentioned he made a stand for the jack to get the top extensions. Since my floor jack will allow me to hit the first ESCO position, only, my stand would need to be the height of the next 4 positions. Is anybody using an extension on top of the jack pad, and if so, what does this look like? My gut tells me that I'd feel safer with an extension platform under the jack rather than on the pad, but exploring all options for now.
Right now I am picturing some 19mm plywood on the top and bottom of a 2x6" frame, with blocks of wood on the top side screwed down to "frame in" my floor jack to keep it from slipping of the top. |
Originally Posted by Paul902
(Post 11499937)
Right now I am picturing some 19mm plywood on the top and bottom of a 2x6" frame, with blocks of wood on the top side screwed down to "frame in" my floor jack to keep it from slipping of the top. Extension that long on top of jack will star falling over after certain point, unless there are jacks that simply lift vertically without rolling. |
https://rennlist.com/forums/993-foru...light=jack+993
I also plan on buying a second lo pro jack that goes higher. Now I am using blocks of wood and a hockey puck. |
I normally try to avoid HF, but took a chance on this jack. It fits under my car with no need for the 2x12 ramps (at ROW sport height) and goes up to 23 3/4" high. Seems to fit the 993 very well, is priced right, and easy to acquire. Curious to see how long it lasts.
http://www.harborfreight.com/automot...ump-68050.html |
(Post 11499616)
Now that i thought more about it, I think putting front on jack stands first will do it. Just sucks having to do it if I only need the rear raised.
