993 Forum 1995-1998
Diagnose Shift Linkage Issue
Old 06-15-2014, 04:58 PM
Cactus
Noodle Jr.
Cactus's Avatar
Default Diagnose Shift Linkage Issue
So I am having some issues with my shifting. Weltmeister short shifter with Golden Rod. Left to right spring is not working when I push the shifter to the right. It won't spring back on its own.
Old 06-15-2014, 07:19 PM
Paul902
Paul902's Avatar
Hmmmm....bottom of shifter rubbing on the cover plate? No grease on the clamshell that goes around the torque tube (or whatever exists there on an 2wd)?
Did it suddenly get like that, or slowly get like that?
Old 06-15-2014, 08:16 PM
Cactus
Noodle Jr.
Cactus's Avatar
Not rubbing. This video was with the tunnel cover off. Never shifted great but seems slower these days.
Old 06-15-2014, 08:25 PM
therossinator
therossinator's Avatar
The springs that return the shifter to its normal position are located within the transaxle. And pretty deep in there at that.
Old 06-15-2014, 10:38 PM
Cactus
Noodle Jr.
Cactus's Avatar
Hoping for an easier fix...fingers crossed.
Old 06-15-2014, 11:01 PM
Ponchobroke
Ponchobroke's Avatar
Did you just install the short shift? If so did you remember go change the idler tube yo the upper position?
Old 06-15-2014, 11:14 PM
Cactus
Noodle Jr.
Cactus's Avatar
Yes this was all done a few years ago. I have just been dealing with it for a while but finally want to fix the problem.
Old 06-15-2014, 11:39 PM
therossinator
Do you feel a lot of resistance when you move the stick to the right or is it pretty smooth and effortless?
Old 06-16-2014, 09:01 AM
Cactus
Noodle Jr.
Cactus's Avatar
It is the same left and right. It is kind of tight but I chalked that up to the short shift kit.
Old 06-16-2014, 01:45 PM
Cactus
Noodle Jr.
Cactus's Avatar
Is there a way to test the side to side with the linkage apart? That way I can see if it is the linkage or internal problems.
Old 06-16-2014, 02:20 PM
MarkD
MarkD's Avatar
hey dood...
disconnect the shift rod from the shift fork.
The shift lever should then move around freely.
If it doesn't, the problem is in the shift box area.
Also, with shift rod disconnected, try to rotate the shift rod when in neutral.
It should spring back to center.
If it doesn't... then it's the trans
Old 06-16-2014, 07:10 PM
AOW162435
Seared
AOW162435's Avatar
Originally Posted by MarkD
hey dood...
Sage advice.
Andreas
Old 06-16-2014, 07:35 PM
Paul902
Paul902's Avatar
Cactus, I hope you don't need to get a close ratio gearbox to fix this...
Cactus
Noodle Jr.
Cactus's Avatar
Looks like the both heim joints on the front shift rod froze. This is very good news. Lubing my joint (s) as we speak
Old 06-16-2014, 08:15 PM
MarkD
MarkD's Avatar
very good news!
Glad it was not $$$
Quick Reply: Diagnose Shift Linkage Issue
