in trouble for flashing people in public? airbag light won't extinguish? click here!
I flashed people, & I couldn't help it. It got me in trouble
If you have the same problem & can't find relief, the solution may be changing out your steering column switches & stalk, part #993 613 353 00.
For me, the headlight stalk would randomly move a smidge (technical term) forward when my lowbeams were on, activating my highbeams at unintended times. Usually just a quick flash, sometimes longer. It's one way to get attention & meet people, but I really wouldn't recommend it
I finally met one other enthusiast familiar with this. He said the tension holding the stalk back can lessen with age, & is especially prevalent after you've just had your turn signal on. A bit more common in 964s, IIRC.
Part #1 in this Porsche PET diagram:
From installing that, my airbag light illuminated & could not be extinguished. No way, no how. Would NOT reset. The dealer & two independent shops tried to help. They used at least 3 Porsche diagnostic tools that 'always work' - the standard ones like the PST2, Bosch hammer, etc., but nothing did the job for my '95 OBDI. For 5 days they worked on finding an answer, eventually revealed at a race shop.
If you ever experience a similar problem, this may be your salvation:
The BAUM T.U.I. CS2000. It's no longer produced, which may also make it more difficult to find, so I wanted to post my photos in case this info helps anyone searching. (A slightly related thread my searches found was RLer pp000830 (Andy)'s "Replaced the steering column switch assembly" thread.)
Ensure you have the proper cartridge.
^^ Last image's from an eBay auction. No affiliation.
The airbag light issue, I believe has to do with which airbag controller is in your 993. Under 993 Durametric Software won't clear the light. Under the 964 menu it will for my 993. Go figure?
