rs sway bar
can a 993 rs front sway bar be mounted to the normal drop links? If yes, any reason why it might be a bad idea?
Cheers,
Boris
Cheers,
Boris
Tom,
I already have the weltmeister adjustable bars - but they are noisy and i found someone that would sell me a used rs front bar. but he doesn't have the RS drop links. since they built to the same spec i thought it would be ok to mix a rear weltmeister and a front rs bar.
so it shouldn't make me go any faster. however what will is a light weight flywheel - i'm really tempted on that one....
cheers,
boris
cheers,
boris
