DIY - Steps to R&R the Resonance Flap
Building on the last DIY on testing the engine flaps, here is a DIY that
addresses the issue of repairing and replacing the resonance flap.
DIY can be found here: https://drive.google.com/file/d/0B9n...it?usp=sharing
-bruce
-bruce
Thanks bruce7
I have read many of your posts and appreciate your efforts.
I will read this one tomorrow but must say after doing this DIY my CEL went off Last week!
Thank You
TJ
Thank You
TJ
for many thousands of miles before checking. I found a leaking VRAM vacuum
unit and a leaking y-piece. I also replaced the check valves behind the "tree"
for good measure and the 4-way distribution piece going to the vacuum reservoir.
Then the R&R of the resonance valve. After all that the car was much stronger,
accelerated better and made for smoother shifting.
-bruce
+1
I found my car drove vastly superior and pulled nicer through its rev range since the DIY of the Resoonance Flappe and Vacuum Unit Replacement.
Additionally I wish to point out that the Y or TT Pipe was fine in warmer weather, but once into the Fall when driving in cooler weather, my y-piece which was great in 70 degree weather actually drooped in 50 degrees.
Just wanted to share this additional bit of info for others whose cars are driven in colder climates and suddenly find an issue.
Excellent Write Up
Highly detailed
Thanks!!
TJ
Excellent Write Up
Highly detailed
Thanks!!
TJ
