993 Forum 1995-1998
Part number?
Old May 17, 2014 | 10:34 AM
martyp's Avatar
martyp
Question Part number?
Anyone know the part number for the wire retainer clip shown here? This mounts on the front shock and holds the brown ABS ground (?) wire. (photos courtesy of crw in the Koni FSD install thread). I don't see this identified in either the PET or WSM
File Type: jpg
File Type: jpg
Old May 17, 2014 | 11:39 AM
NP993's Avatar
NP993
Having a similar problem here. Found that the black bracket holding the white plastic barrel cylinder part onto the strut had fallen off, and after who knows how many thousands of miles of hanging free, the brown ground wire had broken off at the barrel body.
Anyone have part numbers for the bracket and white barrel item? As Marty says -- this stuff (so far as I've been able to find) is not in the factory manuals.
Old May 17, 2014 | 12:38 PM
martyp's Avatar
martyp
NP - Not sure about the round, white ABS connector, that might be part of a wiring harness. The black enclosures used to secure the ABS connector to the shock are (just quoted from Sunset):
Qty 1 ea - 928 612 531 00 (left front ABS connector housing for shock absorber) $5.51
Qty 1 ea - 928 612 531 01 (right front ABS connector housing for shock absorber) $5.51
Old May 17, 2014 | 02:17 PM
NP993's Avatar
NP993
Thanks Marty
Old May 19, 2014 | 01:02 AM
martyp's Avatar
martyp
Ferris? Anyone?
Old May 19, 2014 | 03:37 AM
bcameron59's Avatar
bcameron59
Suspect this is part of the ABS wiring harness 964 612 184 01 "wiring harness anti-lock brake system brake pad wear indicator" on PET / katalog, illustration 902-15, pos. 6... If so, not cheap. Or maybe part of the assembly kit, 964 612 984 00, same page, just after pos. 7, a lot cheaper at about $13.
Old May 19, 2014 | 03:15 PM
martyp's Avatar
martyp
Thanks Brian I was coming to that conclusion. I'll query Sunset and report back
Old May 24, 2014 | 09:46 PM
martyp's Avatar
martyp
Looks like I'll be using the original clips. Sunset tried to no avail - it may come with the harness or the install kit - there is one kit in Germany, not worth the wait.
Old May 25, 2014 | 11:57 AM
ReinerFink's Avatar
ReinerFink
I have some used you can have for the cost of shipping. PM me if you are interested, however I suspect you wanted new ones to finally beat that other guy in the concurs show...
Old May 25, 2014 | 06:06 PM
martyp's Avatar
martyp
Ha! Thanks for the offer - I can't even spell that event correctly
Old Nov 8, 2024 | 02:26 PM
Phil Robinson's Avatar
Phil Robinson
Cruisin'
The part number the small white clip with the push pin that holds the brown ground wire is 999 591 932 40.
For some reason it doesn't appear on the 993 parts list, but its on the 964 list.
Old Nov 8, 2024 | 04:46 PM
bcameron59's Avatar
bcameron59
Nice detective work!
Old Nov 8, 2024 | 05:50 PM
pp000830's Avatar
pp000830
Dare I say the secret word... tie-wrap?
Old Nov 8, 2024 | 06:59 PM
bcameron59's Avatar
bcameron59
BLASPHEMY !
… but I’ll sheepishly admit that’s what i did when mine broke
