993 Purchase Question
In January I bought a higher mileage '95 in Monterey. It was a private party sale and the seller was very picky about how far he had to drive for a PPI. I ended up going with the Porsche dealership in Monterey. Their prices were a bit high for the inspection and a leak down/compression test wasn't included in the standard PPI. (Be sure to insist on a leak down/compression test during the inspection. It will add time and $$$ but it is worth knowing if the engine will need work right away.) The PPI was pretty accurate about the various problems with the car, so fart there have been no ugly surprises for me. Just a long fix-it list that I knew I'd be getting myself into from day 1.
This cars are old and regardless of mileage, rubber bits have aged and need replacement. Expect to put some serious money into the suspension if it hasn't already, recently be done.
All in all, I wouldn't do a dealer PPI if you have the choice. If you don't have a choice, like me, Porsche of Monterey isn't the worst to deal with.
Two more quick questions...
1. When the car was started, it had white smoke (fair amount) come out of the tailpipes. This lasted only a second or two, then nothing. Is this pretty normal, or does it indicate some sort of issue?
2. The oil level gauge (one on the far left?) rose slightly into the red when I started the car, but never went any higher. It didn't move at all during the test drive. Is the gauge potentially broken or the car low on oil? I would say the needle was halfway into the red, but there were no other warning lights on the dash (and frankly didn't notice until halfway through the drive). Thoughts on this one?
Thanks.
Thanks.
Thanks.
Thanks.
Attached is a list of most of the common items on a 993 that end up needing some work. For this you can probably develop 993 specific inspection items beyond the basics that should be looked at on any used car.
I'm still a novice to the 993 world, but is guess the smoke at start up might be leaky lower valve cover gaskets leading to oil dripping onto the exhaust. I seem to be experiencing similar symptoms.
Fixing those lower valve cover gaskets is on my short list. It is suppose to be a pretty easy self repair if you are into DIY.
Do some searches on the 90k service, it's important that you know the potential costs coming at you should you choose to purchase it. Also keep in mind that things that sound simple like cracked/worn plug wires that come up in the PPI should not be blown off until you've researched the costs associated. That's one example of an item that is more expensive and time consuming to replace than most other cars and can come as a surprise later. It shouldn't be a deal breaker but you should be informed.
Good luck and I hope this one works out.
"The engine smokes a bit on start…not concerning. Very common in 993s. The oil turns into a foam and sits in heads, drains into valve seats and then when you start it blows smoke out tailpipes."
Mark
Update on the car, it finished an initial PPI today, a quick recap of results:
- Has oil leaks (lower valve cover gaskets, possibly oil return tubes, cam cover housings and center case). Sounds like fixing the valve cover gaskets would get most of the leaks, but the others remain and sound expensive potentially down the road. Could these others wait awhile?
- Will need a new clutch relatively soon. It is apparently engaging pretty high up, but not slipping or showing other signs yet. That said, likely an imminent item.
- The airbrake (not sure if this is the right word) that funnels air into the engine from the spoiler when deployed is broken and needs fixed. Spoiler works, but this part is broken.
- The heater and AC work, but the heater when turned to max doesn't actually blow harder. This may be blower related, or something else, the person doing the PPI couldn't tell. Anybody have this issue? As long as the heat works in some capacity I'm not overly concerned initially, but curious how expensive this might be to fix down the road.
I haven't done a leakdown and compression test on the car yet, I'm getting a quote of an additional $1100 minimum to do this. That said, C&C (where I had the PPI done) strongly urged me not to do it as they feel the engine is healthy from what they've seen (driving the car, no rough or lopsided idle).
So remaining questions...
1. The car is listed at 38.9k. Based on this information, what would you pay for it? No service records and an accident on the carfax (no damage found by the PPI today, believe it was minor).
2. Would you spend $1100+ for a compression/leakdown based on the above?
Thank you all again for your help, this forum is awesome!
Can't tell you what to pay for the car though it sounds like it has a number of not insignificant needs. I would question the competence of the place doing the PPI though based on the fact that they "strongly urged" you not to do a compression & leakdown test and then quote you more than $1k for the job - probably to further discourage you.
I've never heard of such a ridiculously high price for that job. They're most likely not interested in your business for some reason. Doesn't sound like a reputable business to me. Sorry to be a downer.
I've gotten the price down to 33k based on the inspection results, but that's as long as the seller will go. Does anybody have experience using Porsche of Monterey for a compression test/leakdown?
Unfortunately, the seller won't let the car leave Monterey. I think Porsche of Monterey is my only other option. May see how much a compression/leakdown runs there. Sure it isn't cheap! If anybody knows any place else, please let me know. The $1100 quote was from C&C.
