Trial awdectomy?
No disrespect to Quad, as I am sure he is a capable driver. But for the love of God, please don't lift in a corner to test this out. I never enjoy that "ride' with my students and the sometimes subsequent THUD that occurs.
The car does push, but what are you going to do, lawyers got to the designers =-)
I wouldn't recommend it at absolute adhesion limits, but at 8/10s on a fairly stock AWD 993, anything but a horribly abrupt lift shouldn't cause any real oversteer. Certainly nothing like an early car.
Porsche provides a purpose built component for this, or you can just use a stub axle.
Sorry, don't have the P/N of the component handy.
Other than that it's as Ken says, easey-peasey.
really? I've done a fair amount of hard driving and I've never had the car oversteer...ever. In anything resembling stock form (and my car is not stock with 030s/hd, hr sways, aggressive alignment, etc) these cars push like whales. You'd need to really do some hamfisted throttle work to get the car to hang the tail out...or pound on the brakes mid corner. Even lifting in a corner doesn't really bring the rear around in my car.
indeed yes.
but
There was certainly "hamfisted throttle work to get the car to hang the tail out.", though I prefer it to be called pitch-n-catch maneuvers to shorten the path through a corner at an AX.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
PS, it seems to work equally well in RWD or AWD configurations as long as I apply sufficient input....................
Craig
On the other hand, if you come into a corner too hot, you will experience significant oversteer.
I'll add that I am running stock 17" Pirellis, so better rubber would probably change this behavior. Also I am a total rookie in the Porsche and as such I am open to being corrected in my interpretation of the handling.
really?
indeed yes.
but
Craig
indeed yes.
but
Craig
if you guys are applying some scandanavian flick to the driving process that might account for it.
but i'll tell you, with about 80% throttle on 2nd gear hairpins, i get zero wheel spin and the car will push if you're on it hard. This assume a slow in/fast out style. if you trail brake it, the front does tuck in fairly well, but the rear doesn't come around in any noticeable way.
I run 235/295s, so that may help.
Mine C4S pushed/understeered like a pig in AX (even after the AWD died) with 225/285 tires, but a 245 front fixed that! I suspect that Quad's 295 rear tire is helping him a bunch. And hopefully he, and all of you, aren't pushing your cars on the street as we might in AX...
I second that AWD 993 understeers very much so especially under acceleration. If you already in a slide, that's a different story. You cab drift anything with steering wheel and lack of traction. Take a look at drifting camrys in middle east on youtube.
