Best speakers for 993
Not to mention that the frames of the speaker may be different as well, causing other fitment problems.
try calling Rod Birch at Car Audio Innovations http://www.caraudioinnovations.com
He knows a ton about Porsches, and can recommend something that will fit with no cutting. Just let him know your budget and what your goals are. Rod is a terrific guy.
I think the most seamless improvement is a swap of the HiFi full range drivers for the Dynaudios out of the VWs. This single change made a huge difference for me, and provides a great foundation on which to build down the road.
https://rennlist.com/forums/9842556-...tml?styleid=13
Thanks both. I know from the 986 world that speaker diameter was only an indicator that the speaker may fit. Some of the speakers had strange mounting brackets (3-screw vs. 4-screw) that required special adapter brackets to mate more conventional speakers with the door panels.
Also speaker depth was a key issue. In certain cases the spaces for the speakers were rather shallow and only a small selection of speakers were short enough to fit the space. Hence my question.
I'll definitely follow up with Rod Birch. Rather than *best* speakers, I'm simply interested in getting new, functional speakers that don't sound horrific to replace the blown originals. I'd like to leave the amp and receiver/head unit stock.
Also my primary *sound system* upgrades planned will be Fister Stage 2/3 and a Motor Sound Intake...
Info refers to 10 speaker hi-fi option.
Rear combined speaker - mid range approx o/d 4 7/16" 3 sided mounting plate. Height 1 5/8". I used a 4" 4 hole mount - cost me $8.00 delivered by UPS from Amazon. Works fine and in the noisy 993 environment perfectly acceptable to me. Bearing in mind Porsche is selling a similar size speaker for $32 and bearing in mind their usual huge mark-up, I estimate the real cost of a Porsche speaker is way less than $8.00! The tweeter is glued in and secured by 2 small torx screws, diameter is 1 5/16" and 5/8" deep - I disconnected it.
Mid range door speaker has 2 hole surround 3 1/8" od x 1.5" high. Low range door speaker dimensions I don't have but can be found from photograph comparing with the mid range. Door tweeters are not connected and i don't, know the dimensions, I haven't pulled them out.
I dumped the Nokia amp and all works fine from a Sony $65.00 head unit. It's actually sounds better than the OE set up.
Received 5,401 Likes
Best speakers for a 993? Buy em from FD Motorsports. They are called Fister 3's or Fister 2's. Done.
mpurden -
The Dyn/VW driver is robust, there's no doubt. The Dyn soft dome driver is running actively crossed at 800hz out to 5khz in the coupes enhanced HiFi door enclosures. The sound pressure level, imaging, etc., are all simply outstanding. Put it this way, the Dyn/VW driver does the much sought after disappearing act, acoustically speaking. This acoustic character only the very best drivers typically exhibit; tight phase coherency across its bandwidth baby. You can listen to the Dyn's all day long... musical and loud when needed. Its an active system w/Digital Signal Processing as a key; dedicated control of each speaker with total control of the system in its environment.
Good DSP is getting cheaper $$ by the minute... Get with it guy's.
I'm currently listening to the Vifa modified OEM tweeter door pods. So far I like these best (given the confine of the diminutive 20mm (3/4') size of the original tweeter door pods) But I'm insisting on stealth. The Vifa tweeter is a nice upgrade for small money.
Good luck moving forward on your coupes HiFi improvements.
After installing the dyns, I thought the high end spectrum of the system was actually pretty good considering the age. Then again, I believe my stock Nokia is putting full range through them. Definitely sounds like it's at or above the 5khz crossover point you mention.
BTW, thanks M. Schneider for paving the trail with the Dyns... they are shockingly good to my worn out drummer's ears, IMVHO. In a past life I did some engineering on Dyn monitors. There's a reason they're in studios... definitely top notch.
Two factors go against it, one, age, the speakers are either drid out, or the baffles torn or both.
Second, digital processing is far superior to what existed 16-18 years ago.
Fresh speakers and a decent headunit from today, will sound much better.
